EagleTree MicroPower E-Logger V4
Evren hocamızın Spitfire Mk9 maiden konusunda paylaşmış olduğu ve çok efektif bir şekilde kullandığı "EagleTree MicroPower E-Logger V4" bir göz atayım dedim.
Heliciler olarak artık FBL ünitelerin de datalogger özelliği olduğu için extra datalogger kullanmıyoruz ama fonksiyon olarak cihaz oldukça başarılı gözüküyor %p
İhtiyacı olan arkadaşlar değerlendirebilir.
Kullanım detayları ve yorumları Evren hocamdan eklemesini özellikle rica ederiz ;)
Ürün linki :
Fiyatı : $ 60
Özellikleri:
* Logs pack current to +/- 100 amps peak (150 amps peak with MPRV4-LEADS-150) and voltage from about 5 volts to 80 volts
* Current is measured with a true Hall Effects Sensor - NOT a power robbing resistance shunt
* Adjustable logging rate (from 50 samples per second to one sample every 5 minutes)
* 16 times the logging space of the standard eLogger V3, and lossless data compression. Typically logs all available sensors for about four hours, at 10Hz.
* All data logged to permanent memory, which retains the data even when the power is removed
* Fully compatible with our OSD Pro expander
* Includes Y cable for throttle position logging
* Great for bench monitoring of battery charging also!
* Supports the PowerPanel LCD Display
* Accepts optional inexpensive sensors for three Temperatures, RPM (brushless, magnetic or optical), Airspeed, Altitude, GPS, Servo Current, and more
* Software computes Wattage, mAH, etc. for complete e-flight data
* Fully Compatible with Windows 7 (32 and 64 bit), Vista, 98SE, ME, Win2K and XP™
* Weighs about 0.8 oz (22 grams). Versions with Wire Leads may weigh slightly more.
* Comes with our state of the art Windows virtual playback display and graphing software
* Powerful Graphing software has advanced charting features, such as amps vs volts
* Internet Updatable firmware - as we add new features or (heaven forbid) have a firmware bug, the update is just a download away! No need to ship hardware back and forth.
* Full support for English and Metric units.
* Software has built in English, German and Chinese language.
Extra LCD Monitore ve Sensorleri:
Altimeter MicroSensor V4
Abi foruma Türkçe desteği mi koysak :)
