[Urun]: Micro Brain Flybarless Unit (MSH 51621)
Rasim Öztürk
9 Mar 2013
Eskişehir
Başarılı Brain FBL ünitesinin mikro boyuttaki heliler için yeni versiyonu çok yakında piyasada olacak. Kendileri Blade 180cfx modelindeki ünitenin direct replacement i olur. Uygun konnektörler vs. kullanılarak diğer benzer boyuttaki helilerde de kullanılabilir.
Fiyat olarak 80-90 pound civarında olacak, yani 300-350 tl gibi...
Ürünün fotosu ve özellikleri ise şöyle;
*RX support Spektrum DSMX DSM2, Futaba S-BUS S-BUS2 PPM SUM, Graupner Hott Sumd, Multiplex SRXL, JR XBUS B, UDI (all connection cables included)
*Self leveling/Rescue
*Optional Bluetooth module with Android App
*3 flight banks. Great for trying new settings, optimizing for diff headspeeds, etc.
*Pitch Pump. Really helps with micro collective authority making tic tocs much easier, and pop and lock a lot more fun
*Ability to save and share config files with other pilots
*Built in flight counter
*Full PC interface for configuration.
*Support for custom cyclic servos like the blue arrow that require reversing
*Support for higher end tail servos
*Superior vibration immunity based on hardware filter technology. Very high tolerance to models that are not so perfect (many crashes on mine with extra vibes but still flies great)
*Incredible piro consistency through high speed maneuvers. Piro comp
*Fully tunable tail including tail precomp, stops etc. the improvement on the tail is profound
*Easy servo position trimming for the cyclic and tail.
*Much greater ability to tune and optimize for different blade choices
*Big firmware improvements over time. A lot of Brain features coming that work with the uBrain and full size.
Test videoları;
Bluetooth ile ayar imkanı;
Türker Akgün'den bir atak bekleniyor :laugh:
Bu modeller mikroluktan çıktı artık. RAR'lanmış 700 bunlar. :lol: :lol:
Bir atak gelir mi dersek, kaşıntı krizinin ne zaman geleceği hiç belli olmuyor birşey söylemek zor. :laugh:
Ben küçük yep escyi tutayım, lazım olacak gibi görünüyor :yuppi:
Brain çok akıllıcı bir hamle :thumbup: Bu arada dikkat ettim de özellikleri arasında :
Kurtarmada ilave edilmiş. Acaba bu bildiğimiz ve Ikon kullandığımız özellik mi yoksa gerçekten RESCUE geliyor merak ettim doğrusu :rolleyes: ???
Seçilen modelin 180 CFX olması da ayrıca manidar :laugh: :D Daha öncede dediğimiz gibi model şahane ama düşürmemek gerekiyor :lollol:
Rasim Öztürk' Alıntı:
Bu arada Türker'den daha büyük bir şeyler bekliyoruz :laugh: ;D
250 sınıf için de oldukça ideal bir ünite gibi görünüyor, minik ve marifetli..Bir bakalım zaman az biraz geçsin.....
Brain olur da ikon olmaz mı... Ne de olsa tek yumurta ikiziler :laugh:
Pembe mi o yoksa fotoda mı öyle çıkmış ;D
Üç kuruş fazla olsun, pembe olsun bre.... :D ;D
Güzel alete benziyor. Sanırım şimdilik satılmıyor. Peki çalışma voltaj aralığı hakkında bilgi var mı 1s ile çalışır mı. :-\
Herşey sır gibi Serkan hocam, mart ortası bekleniyor. Pre order lar alınmaya başladı.
Rasim baktım da bulamadım. Hangi sitede preorder.
Birçok ingiliz ve amerikan sitesinde... Fastlad çabuk gelir tabii... Ve depozito alıyor şimdilik sadece... Diğerleri tam fiyat.
10 Mart gibi bekleniyor.
