[Urun]: SJcam M10 Cube Action Camera (Birileri şu Çinlileri durdursun)
Nesimi Sakmak
9 Kas 2013
Manisa
Evet birilerinin bu Çinlilere bir dur demesi lazım. Adamlar direk cüzdanlarımıza çalışıyorlar. Yeni SJCam satışta. SJ 4000 le aynı özelliklerde ama bir boy küçüğü gibi görünüyor. Sanırım yeni hedefleri Mobius.
Description:
1.5 inch Ultra HD screen
12-megapixel HD wide-angle lens
HDMI HD output and AV video output
Vehicle-mounted recording
Detachable battery that is easy to replace and prolongs your SJcam M10 action camera’s service life
Recorded in MOV format
Multiple video recording formats: 1080P 720P WVGA
Multiple photo shooting modes: Single shot, Snapper
Video encryption enabled
SJcam M10 camera Support storage cards up to 32GB maximum
Water-resistant up to 30 meters under water.
The water-resistant casing allows you to film fascinating water sports with SJcam M10 underwater camera.
This cube action camera has mini appearance, diversified colors available:Black, Blue, Red, Sliver, White, Yellow.
Specification:
Liquid Crystal Display (LCD) 1.5LTPS
Lens 170°A+ HD wide-angle lens
Language Options English / German / French / Spanish / Italian
Portuguese / Chinese Traditional / Chinese Simplified / Japanese / Russian
Resolution of Videos Recorded 1080P (1920*1080 ) 30FPS
720P (1280*720) 60FPS
720P (1280*720) 30FPS
WVGA (640*480) 60FPS
Video Format MOV
Compressed Format of Videos H.264
Resolution of Photos 12M/8M/5M
Storage Micro SD
Shooting Mode Single Shot / Self-timer (2s / 5s / 10s / Continuous Shooting
Frequency of Optical Source 50Hz / 60Hz
USB Interface USB2.0
Power Source Interface 5V1A
Battery Capacity 900MAH
Power Dissipation 400mA@4.2V
Recording Time About 1080P/ 90 minutes
Charging Time About 3 hours
Operating System (OS) Windows XP/VistaorAbove/Win7/Mac os
Dimension 48.1*43.3*43.4
Ürünün daha az aksesuarla daha uygun fiyata olanı ve Wifi özellikli olanı da var. Hiçbir açıklama da ağırlık bilgisine rastlamadım. Mobius'a yakın bir ağırlıktadır diye tahmin ediyorum. SJ 4000 başarısı düşünülürse mini quadlar için çok güzel bir alternatif olacağı kesin. Denemek lazım.
Çok güzel bir alternatif daha. :thumbup: Gopro'nun koltuk sallanıyor. :laugh: :lollol:
Teşekkürler Nesimi Bey paylaşım için, inşallah kullanan bir arkadaşın yorumlarını da alma şansımız olur. :RCKolik:
O kadar siteye baktım. Sanki özellikle yapılmış gibi hiçbir yerde ağırlığı belirtilmemiş.
Fatih TANRIVERDİ' Alıntı:
SJ 4000 den hafif olduğu kesin. Onun ağırlığı 60 gr. Bu da 40-50 gr arasıdır diye düşünüyorum. 60 gr olsa bile boyutlar küçüldüğü için daha kullanışlı olacaktır mutlaka...
Bu çinliler de işin suyunu iyice çıkardılar valla :lollol: :lol: Ne çıkarsa alayım desen, sipariş vermeye yetişemeyecek insan :lol:
Bilgilendirme için teşekkürler Nesimi Bey %p
Bu videoyu izledikten sonra düşüncelerim değişti. SJ 4000 i daraltıp şişmanlatmışlar. Büyük olasılıkla aynı özelliklerde ve aynı ağırlıktadır.
