Gunaydin arkadaslar
Servoking ds-995 +ds995i
Asagida ozellikleri belirtmis oldugum combo set satiliktir sorunu sikintisi yok sadece test amacli takilmistir
3 set yada 4 u birden satiliktir
Fiyat olarak adet 40$ dir
Setin tamami 150 $
ServoKing DS-995 + DS995i Micro Servo Combo (4pcs)
Digital Micro Size Servo Made in Taiwan. Can be used as CCPM and Tailservo in Helis as also in Airplanes.
Full Metal Gears / Full Aluminium Alloy Case
We do not add advertising fees to our products to keep prices low (high C/P). Why waste money on over-marketed big brand servos?
Trust SERVOKING to deliver more than the required performance for your heli or plane.
DS-995 Spec:
Operation Voltage: 5-8V(Suggest 6-7V)Weight: 20g(0.71oz)Torque: 2.2(kg/cm)@4.8V2.8(kg/cm)@6V3.4(kg/cm)@7.4VSpeed: 0.04(sec/60∘)@7.4V0.05(sec/60∘)@6V0.06((sec/60∘)@4.8Dimension: 12x23x27.25mmFrequence: 1520us/333hzGear Type: metal Gear
Test Flight
Speed Test
DS-995i Spec:
Operation Voltage: 5-8V(6-7V Best)
Weight: 20g(0.71oz)
Torque:
2.3kg/cm@5V
2.8kg/cm@6V
3.4kg/cm@7.4V
Speed:
0.04(sec/60∘)@7.4V
0.05(sec/60∘)@6V
0.06(sec/60∘)@5V
Frequence: 760us/333hz
Motor Type: Coreless Motor
Setin tamami 150 $
DS-995 Spec:
Test Flight
Speed Test
DS-995i Spec:
Weight: 20g(0.71oz)
Torque:
2.3kg/cm@5V
2.8kg/cm@6V
3.4kg/cm@7.4V
Speed:
0.04(sec/60∘)@7.4V
0.05(sec/60∘)@6V
0.06(sec/60∘)@5V
