SPIRIT YENİ GÜNCELLEME VERSİON 2.0.0 BİR ÇOK YENİLİK VAR.
efsunkar3356
18 May 2014
Version 2.0.0 was released!
We have achieved another milestone in the development! Version 2 arrived right now with a major bunch of news and improvements.
The update is available right now for everyone!
Major configuration improvements:
The Setup Wizard was redesigned to be perfectly simple and strightforward.
Parameters such as Pirouette Optimization and Sensor Compensations are past.
Directions of the Rescue collective pitch and Revomix are preconfigured automatically.
Spirit know a default transmitter reverses and travel ranges of a famous brands.
Channel deflections in the Diagnostic tab are based on the real sticks movement.
Parameter Position has 8 independent mounting options.
Servo reverses and Swashplate were extended.
Governor:
Algorithms were completely redesigned to improve the reaction time.
Throttle Range has a new units [microseconds] (see ESC specification).
RPM changing is significantly faster now.
Autorotation Bailout has no limitations now. (Activated with TC 12% and more)
Better immunity for a RPM sensor noise.
New parameter called Spoolup rampup for the smoothest spoolup start.
Stabilisation:
All stabilisation modes were improved to be even more useful.
Stabilisation (Acro) allow to perform even more acrobatics with aid.
New Stabilisation (Scale) for a scale flying simulation.
New kind of stabilisation called Coaxial for coaxial-like flying.
Rescue (Normal) has a bigger preference to use aileron.
Possibility to set the Failsafe directly in the software.
Spektrum satellites compatibility was enhanced.
Support for the AR7700 receiver with Spektrum SRXL protocol.
New events in the Flight log:
Detection for any corrupted received frame.
Checking for excess noise from the RPM Sensor.
Added support for the Velos model.
New parameter called Rotor Rotation Direction.
Subtrim and Servo Travel Correction corespond with a real servo movement now.
Graphical hints were updated.
Support for FreeBSD operating system.
Possibility to run the software even with 800x600 pixel resolution.
Configration of the rudder end-points was improved to prevent from binding.
New notification of a non-optimal cyclic and rudder ranges.
And much more!
We recommend to perform the update with the latest 2.0 software.
After the update it is necessary to re-adjust the following:
Channel reverses and Travel ranges in the transmitter (default settings are recommended)
Position
Swashplate (Check the servo connection)
Servo Reverse
Subtrim (tuning)
Throttle Range (including ESC re-calibration) and possibly Governor. (if used)
Paylaşım için teşekkürler Erhan ama güncelleştirme sonrası kontrol edilecek bayağı şey var ben iyiyim böyle. :saygilar:
oo güzel haber. Paylaşım için teşekkürler Erhan :thumbup:
Spirit sahiplerine güzel haber. :thumbup:
Paylaşım için teşekkürler Erhan, güncelleme sonrası yorumlarıda bekliyoruz. :RCKolik:
Güzel değişiklikler gelmiş :thumbup: Spirit kullanıcıları yaşadı :halay:
Kullanıcılar şu başlığı takip etsinler bence, birinci ağızdan faydalı bilgiler var gibi;
bu güncelleme ile ünite kolay dı ama daha kolay hale gelmiş. ve kullanıcı hataları baya giderilmiş.
Arkadaşlar son güncellemeyi gerçekleştirdim. advance ayarlar hariç nerdeyse heli setup ını en baştan kuruyorsunuz. yani ayarlar sıfırlanıyor. açı ayarlarını tekrar dan göz geçiriyorsunuz. kumandadan verdiğiniz tüm reverse leri iptal ediyorsunuz. tüm reverse leri fbl den veriyorsunuz.
peki bunun yararın ney. yararı şu: kurtarma artık optimize etmeye gerek kalmıyor. fbl ne konumda olduğunu ve tüm reverse leri bildiği için, direk doğru şekilde çalışıyor.
diasnostic ekran da çok kullanışlı hale gelmiş.
kısaca sı herşey pozitif yönde olmuş. tabi daha birsürü değişiklik var ama ben bu kadarını farkettim.
Bilgilendirme için teşekkürler Erhan'ım.
ben şu an için oynamayayım en iyisi, ilerde bakarız duruma göre, önce ağzımızdaki cevizleri kırmam lazım :laugh:
Özellikle piyasada bilinen kumandalara özel ayarların otomatik olarak geliyor olması gerçekten büyük bir kolaylık. Hep düşünmüştüm niye üniteler buna göre kendileri ön ayarları yapmıyor diye. Spirit bunu bu sürümde ilave etmiş ve gayette güzel olmuş :thumbup:
Diğer yenilikler de bence gayet göz doldurucu (Daha kolay Setup Wizard, Tamamen Yenilenmiş Governor özelliği, Rescue iyileştirmeler..... )
Futaba için çıkarılmış bi güncelleme o kısmı :laugh: throttle reverse...
Sadece reverse mi var, yoksa kanal sıralamaları da mevcut mu bilinen belli başlı kumandalar için?
Yok Rasim öle kumanda için değil. Normalde reverse lerin bazılarını kumandadan veriyorduk. Şimdi bunlar spirit de 4 ayr servo için 4 ayrı reverse özelliği koymuşlar. Zaten swash seçimi özelliği geldiği için. Kumandadan reverse gerek kalmıyor.
SM-G900H cihazımdan Tapatalk kullanılarak gönderildi
