IKON'nın yeni sürümü olan "2.0.025" çıkmış
Temel bazda JETI kumandalar ile entegrasyonu içeriyor.
INDIRMEK İçin :
Ama aşağıda görüldüğü üzere bizleri de etkileyen bazı revizyonlar söz konusu
-- Swashplate HR3_135
-- 4 new icons for the fast selection between Basic, Advanced, Counters, Diagnostic
-- New tail gear ratio in Governor (basic & advanced)
-- Vertical bars for Main Rotor, Tail Rotor, Engine actual RPM
-- Actual values of Main Rotor and Engine
-- Changed "Power Voltage below 12,5% than startup" to "Power Voltage below 16,6% than startup"
-- Real time vibrations works on Atom PC and slow PC
-- Log is loaded from the unit also the vibrations are downloaded and vice versa
-- Corrected for iKon the connection schematic for SUM/SRXL/UDI/Xbus-b
-- Rescue Gain is fixed and no more editable
-- The label "Gain" was changed to "Tail Gain"
-- When one of the logs is downloaded from the unit, remain in memory until the end of the session. Changing logs is no longer needed to download the precedent log again
-- AUX channel for Auto Level/Rescue is again usable with standard receiver
-- “Rescue pitch max” and “Rescue pitch duration” are enabled only if "Use Rescue" is checked
-- "Auto Level gain" is enabled only if "Use Auto Level" is checked
-- Maximum gear ratio allowed values for Main and Tail is now 32.500
-- Now when the application start, the windows is at full screen
-- New French translations
-- Some instructions corrected / completed
-- Small bug fixes and optimization of code
INDIRMEK İçin :
