Futaba T16SZ ve Futaba 12K Kumandalar
Futaba 2 yeni modelle karşımızda. Aslında modeller çıkalı biraz zaman geçmiş ama biz fark etmedik galiba. İşte modellerimiz ve temel özellikleri
FUTABA T16SZ
Fiyat : $ 699
Link :
Ürün inceleme videosu
Genel özellikler
Compatible with FASSTest, FASST, T-FHSS and S-FHSS protocols
Full telemetry compatible
4.3" LCD touch screen
10 programmable mixes
S.Bus servo programming editor
S.Bus trainer port
3-axis gyro support
30-model memory with 15 character naming
3-axis gyro support
Swash and throttle mixing
V-tail mixing
Adjustable servo speed
AFR/DR
AFR curve mode (3)
AFR curve point (17 points)
Idle down
Logic switch
8 flight conditions
Throttle cut
Voice message/audio earphone jack
Micro memory card slot
Software updateable
Up/down/integral timer
Free online software upgrades
Lap timer memory
Stick calibration
180° antenna rotation and 90° angle adjustment
Multi language (9 languages)
EPA
FUTABA 12K
Fiyat : $ 450
Link :
Channels: 14 (12 proportional, 2 switched)
Compatible with T-FHSS and S-FHSS protocols
Six 3-position switches, two 2-position switches, two slider levers, two rotary dials, four digital trims and two push buttons for quick, easy access
Headphone plug, trainer port and S.Bus plug-in
S.Bus2 system allows multiple servos, gyros and telemetry sensors with a minimum number of cables
Model types: six types of main wing with three tail types for airplanes, six swash types for helis and multi-rotor functions
Improved stick feel with adjustable lengths and tension
Dual rates/exponential
Included 6V 1800mAh NiMH battery and charger
Large, backlit LCD screen with adjustable contrast for easier reading. Push/dial operation simplifies set-up
Micro memory card slot for storing model information and free system updates. (SD-32MB to 2GB; SDHC-4GB to 32GB, not included)
Vibration feature alerts pilots to various alarms and timers, in addition to sound
10-character model naming
Expandable 30-model memory
5 flight conditions (Helicopter and Glider model selections)
5 customizable programmable mixes
Servo test and servo position display
Fuel mixing
Stick calibration
Servo speed
Logic switching
Futaba kumandalara hayranım ancak fiyatları dudak uçuklatıyor.Alıcıları da bir hayli pahalı.Paylaşımınız için teşekkürler Mehmet abi. :)
Valla canim çekiyor ama şimdilik 8fg ili iyiyim zira fhss desteklemiyor ama olsun
