Evvet arkadaslar, baslikta dedigim gibi. Blade 180CFX. Benim de umutla bekledigim 130v2 gibi bir seyden haber yok, yerine bu var
Hakkinda konusulanlar rotary servolarla gelecegi yonunde. 180'den anladigim, 180mm pallerle gelirse, benim mikro anlayisima gore fazla buyuk olacaktir ama, hayirlisi diyelim
Key Features
Optimized servo geometry for flawless control
AS3X® technology with piro-compensation
Reliable Castle Creations Talon 15 ESC
Rigid carbon fiber side frames deliver a solid structure
Integrated bearing block servo mounts
Digital high-speed Spektrum™ nanolite rotary servos for long-lasting precision
Spektrum™ DSMX® AR6335 nanolite receiver with AS3X flybarless technology
Powerful, 5800Kv brushless outrunner motor
High-output 450mAh 3S 11.1V 30C Li-Po flight battery (included)
Efficient torque-tube drive tail with ball-bearing support
Aluminum tail boom and one-piece tail case design
Requires a 6+ channel transmitter with Spektrum DSM2®/DSMX® technology and a suitable Li-Po battery charger - both sold separately
Product Specifications
Main Rotor Diameter: 14.17 in (360mm)
Tail Rotor Diameter: 3.56 in (90.5mm)
Gross Weight: 6.70 oz (190 g)
Length: 13.39 in (340mm)
Motor Size: Brushless Out-Runner, 4000Kv
Kit/ARF/RTF: BNF Basic
Rotor Blade Length: Main: 6.06 in (154mm) Tail: 1.77 in (45mm)
Experience Level: Advanced
Recommended Environment: Indoor/Outdoor
Is Assembly Required: No
BLADE 130X ile BLADE 180CFX Kıyaslaması
130 X : 180 CFX :
Ana Pervane Çapı : 325 mm 360 mm
Kuyruk Pervane Çapı : 76 mm 90,5 mm
Boy : 305 mm 340 mm
Ağırlık : 107 gram 190 gram
Blade 180 CFX, 130X Strecthed, 130X ve mCPx BL modellerin kıyaslama videosu
Key Features
130 X : 180 CFX :
Boy : 305 mm 340 mm
