Blade 180CFX geliyor
Emre Kaman
Moderator
21 Kas 2013
İzmir
Evvet arkadaslar, baslikta dedigim gibi. Blade 180CFX. Benim de umutla bekledigim 130v2 gibi bir seyden haber yok, yerine bu var :) Hakkinda konusulanlar rotary servolarla gelecegi yonunde. 180'den anladigim, 180mm pallerle gelirse, benim mikro anlayisima gore fazla buyuk olacaktir ama, hayirlisi diyelim :)
Key Features
Optimized servo geometry for flawless control
AS3X® technology with piro-compensation
Reliable Castle Creations Talon 15 ESC
Rigid carbon fiber side frames deliver a solid structure
Integrated bearing block servo mounts
Digital high-speed Spektrum™ nanolite rotary servos for long-lasting precision
Spektrum™ DSMX® AR6335 nanolite receiver with AS3X flybarless technology
Powerful, 5800Kv brushless outrunner motor
High-output 450mAh 3S 11.1V 30C Li-Po flight battery (included)
Efficient torque-tube drive tail with ball-bearing support
Aluminum tail boom and one-piece tail case design
Requires a 6+ channel transmitter with Spektrum DSM2®/DSMX® technology and a suitable Li-Po battery charger - both sold separately
Product Specifications
Main Rotor Diameter: 14.17 in (360mm)
Tail Rotor Diameter: 3.56 in (90.5mm)
Gross Weight: 6.70 oz (190 g)
Length: 13.39 in (340mm)
Motor Size: Brushless Out-Runner, 4000Kv
Kit/ARF/RTF: BNF Basic
Rotor Blade Length: Main: 6.06 in (154mm) Tail: 1.77 in (45mm)
Experience Level: Advanced
Recommended Environment: Indoor/Outdoor
Is Assembly Required: No
BLADE 130X ile BLADE 180CFX Kıyaslaması
130 X : 180 CFX :
Ana Pervane Çapı : 325 mm 360 mm
Kuyruk Pervane Çapı : 76 mm 90,5 mm
Boy : 305 mm 340 mm
Ağırlık : 107 gram 190 gram
Blade 180 CFX, 130X Strecthed, 130X ve mCPx BL modellerin kıyaslama videosu
Heli karbon frame'li, talon 15 esc, 3s pil, rotary servolar ve ayri alici ile geliyormus. Simdilik bu kadar, iyi geceler.
Teşekkürler Emre, ama sana katılıyorum 180 mm pal bir mikro için fazla bencede. :(
Karbon frame, tt aktarma, rotary servo, esc, alıcı falan derken, baya bildiğimiz heli oluyor. Evde barkda da uçmayacağına göre, 250 toplamak daha çekici gelebilir. En azından daha büyük :D
Emre Kaman' Alıntı:
İmzanın 3. satırına bittim abi :) Uzakta değil ki arada kullan... Ama tabii önce sahaya inmemiz lazım kullanman için :p
Ben de katılıyorum.180 ile 250 sınıf arasında pek fark yok , 250 daha mantıklı olacak zira artık mikro boyutundan çıkmış sayılır.
şöyle bi yer buldum sanırım bilgilar doğru 154mm pal çeviriyormuş. Benim hoşuma gitti model :)
bu işin sonu yok... bu biter sonra blade195x çıkar... o biter trex352,5 çıkar... tüketim toplumunda olağan durumlar bunlar.
model toplama, mekanik montaj, ayar safhalarını çok severek icra etsem de bir noktada yeter diyorum, güzel güzel uçurabilmeliyim artık. hiçbir şey başarılı bir uçuşun verdiği keyfi vermiyor.
Berkay35' Alıntı:
Teşekkürler Berkay epey bir bilgi var burada. %p
Benim ilk baktıklarımı paylaşayim :
130 X : 180 CFX :
Boy : 305 mm 340 mm
Ağırlık çok artmış bence. :( Bir model ne kadar ağırsa o kadar kolay kırılır. :(p
Ayrıca alışık olduğumuz Blade'in kendine has tarzının dışında olmuş, sanki parça parça topladığımız kitler gibi oluşturulmuş.
Son olarak lineer servolardan vazgeçmekte bence iyi bir fikir olmamış.
Yorum yapmak için henüz erken elbette, bakalım kullanıcı yorumları nasıl gelecek. ;)
Her ne kadar ben tanıtım videolarını dikkate almasamda :laugh: modelin Videosu :
Şahsen ben de pek tutmadım yeni 180 :( Blade sevdiğimiz her özellik bu modelde sanki özellikle kaldırılmış ?? Ağırlığın 2 kat artmiş olması, ekipmanların normal 6 kanal heli ile nerede ise aynı olması...
Neyse bakalım ve izleyelim. Yurtdışı kullanıcı yorumları ne olacak. Şahsen ben hala 130 V2 dört gözle bekliyorum :)
Bu arada bilgilendirme ıcın teşekkürler Emre :)
Arkadaşlar Blade 130 V2 çıkmayacak gibi :-\ Zira aşağıdaki videoda 130 ile 180 kıyaslayıp, 130 problemleri nasıl çözdüklerini açıklamışlar..
Videoyu izleyince 130 problemleri iyileştirmek adında yaptıkları tüm değişiklikler çok tanıdık geldi :laugh:
- Daha güçlü motor ve 3s besleme (130 motorunun yetersiz olduğunu onlarda kabul ediyorlar)
- Daha güçlü motoru beslemek için ayrı bir ESC - Talon 15A
- Lineer servolardan rotary servoya geçiş
- Gövdenin karbon olması....
- FBL ünitenin yeniden kodlanması
- Kuyruk tork Tube dişlilerinin ve kuyruk servosunun değiştirilmesi
- Tork Tube boru içine rulman
Kısaca 130 ile ilgili tüm kullanıcı problem ve upgrade çözümlerini birleştirip, bir üst sınıf helide piyasaye sunmuşlar
Tam aynı şeyi düşünüyordum :D palleri de 150 yapmışlar, siz uğraşmayın, upgrade'leri biz yapalım demişler adeta :) Adını da trex 150'den ayrılsın diye 180 koymuşlardır kesin. Align etkisi bunlar :D ama 180 bana itici gelmişti ilk etapta. şimdi biraz ısındım modele.
veeeeee...böyle böyle bir bakarsın forum 180.ci olmuş................. :lol:
