Rasim Öztürk
Henseleit TDR
Bu arada üstad da Vbar Neo ve Vbar Control öneriyor.
Jan Henseleit will start delivering his latest Heli shortly, the "TDR-II" and later the Variant "TDS" (Speed). He recommends using VBar NEO VLink and VBar Control as the best match.
The special anti balloning system uniqe to VBar NEO 6.1 can shine in this heli, due to the very aerodynamic layout. So its perfect for very high speed as well as low rpm flying. Both are diciplines, that fit the heli very well.
The basic setup is almost perfect for this heli, only very few adjustments may be used to fine tune the behaviour. With VBar Control the adjustment is fun, end even the management of the batterys that are sqeezed out with speed flying is a breeze. So you can focus on flying the heli without all the hazzle around.
A high quality Heli "engineered and manufactured" in Germany is best equipped with a Radio and Flybarless System "engineered and manufactured" in Germany. Same as Jan we are committed to our products and will deliver best support possible.
