Multicopter SMS ile Konum Bilgilerini Öğrenme
26 May 2017
Tekirdağ
Şimdilik modül test videosunu ekledim. Kod yazması yeni bitti.
Bağlantı Resmi
Arduino'ya yüklenecek KOD:
C:
String gpsHamKod, islenmemis, enlem,boylam, koordinat, ns_secim, ew_secim, Arsp, Grsp;
char *ptr;
String googlelink = "https://www.google.com/maps?q=";
#include <SoftwareSerial.h>
SoftwareSerial gsm(10, 11);
HardwareSerial & gps = Serial;
void setup(){
gps.begin(9600);
gsm.begin(9600);
gsm.println("AT");
delay(200);
gsm.println("AT+CMGF=1");
delay(500);
gsm.println("AT+CMGD=1,4");
delay(500);
void loop() {
KoordinatAl();
  if(gsm.available()){
    Grsp = gsm.readString();
    Grsp.replace("\r\r\r\n","\r\n");
    Grsp.replace("\r\n\r\n","\r\n");
    Grsp.replace("OK\r\n","OK");
    Grsp.replace("\r\n","->");
    if (Grsp.indexOf("->+CMTI: \"SM\",")==0){
     int Mno = YeniMesajVar(Grsp);
     gsm.print("AT+CMGR=");
     gsm.print(Mno);
     gsm.print("\r\n");
     String okunan = Grsp = gsm.readString();
     okunan.replace("\r\r\r\n","\r\n");
     okunan.replace("\r\n\r\n","\r\n");
     okunan.replace("OK\r\n","OK");
     okunan.replace("\r\n","->");
     if (okunan.indexOf("->+CMGR: \"REC UNREAD\",\"")>=0){
      okunan.replace("\",\"","->");
      okunan.replace("->+CMGR: \"REC UNREAD","");
      int b1 = okunan.indexOf("->")+2;
      String telnoal = okunan.substring(b1);
      int b2 = telnoal.indexOf("->");
      String TelNo = telnoal.substring(2,b2);
      b1 = telnoal.indexOf("\"->")+3;
      b2 = telnoal.indexOf("->OK");
      String GelenMesaj = telnoal.substring(b1,b2);
      GelenMesaj.trim();
      if(GelenMesaj.indexOf("KONUMAT")>=0){
        String konumm = googlelink+koordinat;
        SmsGonder(TelNo,konumm);
        delay(3000);
void KoordinatAl(){
gpsHamKod= gps.readStringUntil('$');
islenmemis = gpsHamKod;
if(!gpsHamKod.indexOf("GNGGA")){
  gpsHamKod.replace("\r\n","");
  gpsHamKod.replace(",,",",BOSDATA,");
  int str_len = gpsHamKod.length() + 1;
  char char_array[str_len];
  gpsHamKod.toCharArray(char_array, str_len);
  ptr = strtok (char_array,",");
  ptr = strtok (NULL, ",");
  enlem= String(ptr);
  ns_secim = String(ptr);
  boylam= String(ptr);
  ew_secim=String(ptr);
  enlem = Hesapla(enlem);
  boylam= Hesapla(boylam);
  koordinat = enlem + "+" + boylam;
String Hesapla(String gelen){
  char *ptr2;
  int str_len2 = gelen.length() + 1;
  char char_array2[str_len2];
  gelen.toCharArray(char_array2, str_len2);
  ptr2 = strtok (char_array2,".");
  int say1 = atoi(ptr2);
  ptr2 = strtok (NULL, ".");
  float say2 = atof(ptr2);
  int say3 = (say1 / 100)*100;
  say1 = say1-say3;
  float say4 = (say2 / 100000);
  float sonuc = ((say1+say4)/60.0)+(say3/100);
  char buffers[15];
  String tem = dtostrf(sonuc, 5, 6, buffers);
  return tem;
int YeniMesajVar(String mesaj){
int m1 = mesaj.indexOf("->+CMTI: \"SM\",");
int m2 = mesaj.lastIndexOf("->");
int MesajNo = mesaj.substring((m1+14),m2).toInt();
return MesajNo;
void SmsGonder(String telnum,String smesaj){
gsm.print(F("AT+CMGS=\""));
gsm.print(telnum);
gsm.print(F("\"\r"));
gsm.print (smesaj);
gsm.write(26);
delay(500);
