● The easy to use and versatile problem solver putty compound for sealing, bonding, moulding, repairing and
filling.
● Bonds to metals, wood, glass, stone, marble, ceramics, most plastics etc.
● Cured material can be mechanically machined (e.g. drilled, filed, milled) and overpainted without
pretreatment.
● Resists fuels, oil, ester, salt water as well as most acids.
● Used for fast repairs and maintenance works such as;
- Bonding of different type of materials to each other,
- Sealing of pipes and tanks,
- Repairing and building up of casting,
- Repairing of shafts, bearing, pumps, casings, solar panels, radiators and motor blocks,
- Reconditioning of defective threads,
● In all kinds of repairing in manufacturing and automotive industry,
IN THOUSANDS OF OTHER APPLICATIONS THAT YOU CAN IMAGINE
TECHNICAL FEATURES
● Packing: 100 gr
● Curing time at room temperature: 3 hours
● Temperature resistance: -35 ºC to +200 ºC
● Compressive strength: 80N/mm2
● Tension strength: 30N/mm2
Reklam gibi oldu ama,
bunu bir inceleyin. Yapıştı mı ancak mekanik olarak sökebilirsiniz, taşlanabiliyor,delinebiliyor, hatta diş açıp vida bile atmışlığım var.
