Yeni güncelleme geldi 2.4.3
Detayları verelim.
ÖZETLE:
Geçen hafta paylaştığımız Spektrum kumanda entegrasyonu geldi.
Daha önce V 2.4.0 eksik kalan Futaba kumanda Telemetri desteği eklendi.
Tüm bu değişiklikler sonrası IKON ve SPIRIT aynı seviyeye gelmiş oldu
NOT:
Temperature drift compensation: diye yeni bir şey gelmiş ama tam olarak ne olduğunu anlamadım
YÜKLEMEK İÇİN :
Brand new Spektrum Integration:
Added new integration with all latest Spektrum radios! Supported are: DX6e, DX6 Gen 2, DX6 Gen 3, DX7 Gen 2, DX8 Gen 2, DX9, DX10T, DX18 Gen 1, DX18 Gen 2, DX18T, DX18QQ or DX20.
Easily accessible configuration of all parameters anytime you wish!
Supported with receiver SPM4649T.
Can be optionally complemented by Spektrum satellites.
NOTE: Integration guide is available at the Wiki pages.
NOTE: Require Bootloader re-flash.
Telemetry with Spektrum radios:
Support for the Spirit telemetry with all telemetry-enabled Spektrum radios.
Support for the ESC telemetry with the following ESCs:
Castle Creations Phoenix Edge & Talon
HobbyWing Platinum V4
Scorpion Tribunus
Kontronik Kosmik & Jive Pro
Kontronik Jive & PowerJive
Spektrum triple redundancy:
Possibility to connect up to 2x Spektrum satellites and 1x SPM4649T.
All can receive signal to extend signal range.
Spektrum DSM2/X optimization:
Protocol support was rewritten to enhance channel data processing and reliability.
Full support for the SPM4649T serial telemetry receiver.
New Futaba telemetry support:
Support for the Spirit telemetry with all telemetry-enabled FASSTest radios.
Available telemetry variables:
Battery current consumption
Battery voltage
Battery consumed capacity
RPM provided by RPM sensor or ESC
FET temperature of the ESC
BEC Voltage (provided by unit)
Vibration level (0 - 10% is normal level)
Scorpion Tribunus
Works with receivers: R7003SB, R7006SB, R7008SB, R7014SB or R7018SB..
NOTE: Telemetry guide is available at the Wiki pages.
Jeti Telemetry optimization:
Speed-up of the telemetry data transmission.
PWM connection and Wifi-Link compatibility:
When using PWM the Wifi-Link can be always connected to the unit also during power up.
Spirit Pro - Temperature drift compensation:
New compensation that can improve overall flight, stabilisation and rescue precision.
Noticeable improvement when Spektrum satellites and high voltage is used.
Helps during rapid temperature changes.
Setup wizard:
Added new preset for: Goblin Fireball
When changing receiver type, assigned special functions are reseted now.
Updated Bootloader:
Better compatibility with SPM4649T.
Better compatibility with Wifi-Link.
NOTE: To flash new bootloader press CTRL+B keys before pressing Flash button before flashing process.
WARNING: Flash new bootloader only in case that the firmware flashing process is working correctly on your computer. If you do not use Spektrum integration then it is not needed.
