Evet arkadaşlar " EZNOV Neuron" adında yeni bir FBL ünite çıkmış..
EZNOV Neuron flybarless unit // İnceleme Konusu
Hardware :
Latest generation, 9 axis sensor (MPU-9250)
Latest generation STM32F4 microcontroler with floating point unit
Rock solid power stage (no more sat locks) up to 8.4V
Very small : 23.15 x 34.5 x 13.6 mm
6.7g weight
External USB connector for more installation flexibility (cable and adapter provided in the box)
Unplug the USB adapter and you can plug a Bluetooth module instead (same cable).
3 bottom case colors to customize your unit (time limited offer)
Every connector is electrically protected
3M Very High Bond double sided pad provided
Features:
Handles (via different firmwares available to everyone without additional cost) all size helicopters, quads and planes with the same level of performance.
Built-in RPM governor
One built-in sat connector with smart bind (no bind plug nor PC needed to bind)
You can connect a second sat via an adapter
Handles all serial output receivers (HoTT, SRXL, SBUS/SBUS2, JR XBus Mode B and Mode A, PWM sum of course, plus DSM2 and DSMX sats), one wire per channel receivers are supported through an adapter (e.g. SBUS)
Software:
Extreme performance, incredible feeling
Setup and tuning as simple as possible
FREE setup terminal on PC (USB and BT) and Android (BT), all features availables, including firmware update, load/save configuration (compatible files between PC and Android)
iPhone software is work in progress, via a specific Bluetooth Low Energy device available later
Receiver auto-configuration, the unit detects the receiver type and configures automatically the channel assignment, throws, neutrals, reverses, etc at each startup.
Each firmware type (quad, heli, plane) has its own GUI, software user interface is totally adapted for each model type
Upgrading firmware doesn't mean upgrading PC / Android software. You can upgrade one unit's firmware and keep another one on a previous firmware, each one will have the adequate user interface.
RPM governor auto-configuration, ne need to set gear ratio, etc. just plug the sensor, setup a flat throttle curve and fly (both nitro and elec)
Rescue mode for helis, with pitch management
Self level mode for quads and planes
Emre Kamana tesekkurler
Üniteyle baya ilgilendim, program demosunu inceledim. HF'de 18 sayfalık konunun tamamını okudum. Saat 3 olmuş
Özetle:
Ünite için yapılan bazı olumsuz yorumların haksız olduğunu düşünüyorum. Ayrı bir manual hazırlanmamış, ancak programın içerisinde oldukça detaylı anlatımlar mevcut. Özellikle kuyruk tutmasıyla ilgili şikayeti olanlar var, ancak sorunla ilgili detaylı bilgi veren çok az. Sorunun ne olduğunu anlatabilecek kadar kavrayabilenlerin sorunları çözülmüş, ancak bazıları "bu ünite kuyruk tutmuyor" deyip bırakmış. Hani "3gx kötü" diyip bırakıyoruz ya
Ünitenin program arayüzü biraz ikon/brain arayüzünü andırıyor, hatta advanced arayüzü neredeyse aynı, ki bu bence iyi bir şey, ikon advanced arayüzünü hemen her parametreyle oynama şansı verdiği için sevmişimdir. Basic arayüzü ise görüntü açısından ikona göz kırpsa da, ayarlama kısımları farklı. Örneğin swash paralelliğini ve servo subtrimleri ayarladığımız kısımda değişik bir yöntem izlemişler, önce full - yönde ardından 0 derecede leveling yapıyoruz ve full + yöndeki atımı kendisi hesaplıyor, böylece hem iki uçta ve ortada level yapmış, hem de iki uçta aynı açı değerlerine sahip olmuş olarak bir taşla iki kuş vuruyoruz. Governor kısmında (spiritte de olduğu gibi) işi basitleştirmişler, esc governoru ayarlar gibi ayarlanıyor, ancak ben eski düzen, motor pole ve gear ratio girilerek, sabit rpm değerleri yazma işini daha çok seviyorum. Rescue modunu da ilk versiyonda spirit gibi 5. kanala atamışlar, ancak daha sonradan tail gain yüzünden isyan çıkmış ve yeni versiyonda 8. kanala atanmış. 7. kanal ise bank switching için.
Spirit olsun, neuron olsun yeni ünitelerde rescue işini 6 kanalda çözme çabasını hobiye ilk giriş maliyeti açısından (6 kanal kumanda) takdir etsem de, "kuyruk gainime dokunma, benim kumandada kanal bol" diyenlerdenim.
Ünitenin dizaynında öne çıkarılan kavramlar basitlik, fiyatın düşük tutulma çabası ve "heliye bağlı uçuş hissiyatı" (locked). Ayrıca çok yönlülüğe, quadlarda ve uçaklarda da kullanılabilmesine önem verilmiş. Heli, quad ve uçak arayüzleri farklı.
Bir diğer önemli nokta, ünitenin titreşim direnci. Titreşime karşı oldukça toleranslı olduğunu söylüyorlar, hatta karşılaştırmak gerekirse ikondan daha fazla toleranslıymış, ki ikon da baya iyi titreşim konusunda.
Bilgisayar bağlantısı için kutudan harici bir usb modülü çıkıyor ve micro usb kablo ile bilgisayarınıza bağlanabiliyor. Ayrıca crius bluetooth modülleri de bt bağlantısı olarak kullanılabiliyor. İkon, zyx, hk'in multiwii modülü, hatta banggood'da satılan 7-8 dolarlık modüller de kullanılabiliyor. Android app ücretsiz, ayrıca ios app için de çalışıyorlarmış. (Aferin
) Mac arayüzünden ise bahseden yok
Ünitede bana göre iki eksiklik bulunuyor, birincisi port sayısının az olması, ikincisi ise self level modu bulunmayıp, sadece rescue modu olması. Quad ayarlarında self level bulunmasına karşılık heli modunda bu özellik bulunmuyor ve sadece rescue kullanabiliyoruz. Ben rescue olarak adlandırdığımız işin içine pitch karışan durumun artıları kadar eksileri de olduğunu düşünüyorum ve gerektiğinde sadece self levelling kullanmayı tercih ediyorum, ayrıntısına başka bir konuda girerim
Rescue modunun çalışma şekli ise şu şekilde, ünite yer neresi, gök neresi farkında ve rescue aktif edildiğinde heliyi tam olarak düzlemek için zaman kaybetmeden birkaç derecelik sapmayla yerden uzaklaşmaya çalışıyor. Eğer invertten değil de sadece upright olarak rescue kullanmak istiyorsanız, genellikle aileron tarafından dönmeyi tercih ediyor. Bir ince detay, diyelim kumandanızda yaylı switch bulunmuyor. Rescue modun tanımlı olduğu switchi çektiğinizde 3sn boyunca rescue yapıyor, yani heli yükseliyor ve kendiliğinden devre dışı kalıyor. Bir sonraki rescue için switchi bu sefer öbür tarafa çekmeniz yine rescue aktif ediyor ve 3sn sonra yine devre dışı kalıyor.
Son olarak, çıkacağı söylenen yeni ünitenin adını koymuşlar "Sentinel". Sentinel çok portlu, içerisinde ek olarak barometre ve veri loglama özelliği barındıran büyük kardeş olacak. Altitude hold, harici gps modülü de bizzat geliştirici tarafından telaffuz ediliyor. Ancak yeni üniteyi 2015 içinde beklemeyin diyor
Saati 4 ederken, bu ünitenin, özellikle bu fiyattan denemeye değer olduğunu düşünüyorum. Spirit'i denedim, özellikle son iki gündür neredeyse kurcalamadığım yeri/parametresi kalmadı. Özellikle rescue'ya güvenip acayip acayip işlere de kalkıştım, sağ olsun modelimi yere tek parça indirmeyi başardı
Genel olarak memnun kaldım, ancak ikon ve skookumdan alışkın olduğum hissiyatı tam alamadım. Belki bir de bunu denerim ilerleyen günlerde..
Hardware :
6.7g weight
Features:
Software:
