SUNNYSKY 980 KV MOTOR,
HK 20A ESC
KK 2,1,5 KONTROL KARTI
3S 5000 MAH PIL
F450 FRAME
10*4,5 PERVANE
BU SİSTEM İLE YAKLAŞIK 1 AY ONCE UÇUŞA BAŞLADIM. BULUNDUGUM ŞEHİRDE BU HOBİ OLMADIGI İÇİN MEHMET HOCAM ve DİGER ARKADAŞLAR YARDIMCIM OLDU ŞU AN GUZEL MESAFE KAT ETTİM AMA İKİ SORUNUM VAR
1 :blank: CİHAZDA KALKIŞDA HİÇ SORUNU OLMUYOR HAVADA DA GAYET GUZEL AMA İNİŞE GEÇİNCE ANIDEN İRTİFA KAYP EDIYOR. VE GAZ VERMEZSEM YERE ÇAKILACAK OLUYOR O YUZDEN İNİŞİM COK SERT VE ZOR OLUYOR
2 :blank: İKİNCİ OLARAK DA CİHAZ HAVAYA KALKTIKTAN 30-50 SANIYE SONRA KENDI ETRAFINDA YAVAŞ YAVAŞ SOLA DONMEYE BAŞLIYOR HAVADA SABİT DE BIRAKSAM -Kİ ÇOK GUZEL SABIT KALIYOR MOBESE KAMERASI GİBİ ETRAFI TARIYOR.
NOT : ESC KALIBRASYONU YAPILDI
* SELF LEVEL MODE ''ON'' OLARAK UÇUYORUM
* SELF LEVEL KISMI 50-20 OLARAK AYARLI
* KUMANDA RADIOLİNK AT10
ŞİMDİDEN TEŞEKKUR EDERİM.
HK 20A ESC
3S 5000 MAH PIL
F450 FRAME
10*4,5 PERVANE
