[Urun]: Spirit Ver. 2.1.0 SICAK SICAK...
efsunkar3356
18 May 2014
Spirit kulanıcı arkadaşlar yeni güncelleme gelmiş. :halay: :halay: :halay:
gelen en büyük özellik 7 kanal haricinde artı 3 kanala da özellik atabiliyoruz.
İlave olarak...
Version 2.1.0 was released!
It brings many new features and improvements:
Major governor algorithm improvements:
Performance was greatly enhanced by adding dynamic factor into the regulation loop.
Governor is not dependent on the RPM Sensor anymore.
In case of RPM Sensor malfunction, governor will still work (with lower performance).
RPM Sensor failure reported in the Log.
RPM data noise detection feature is more precise. It can distinguish a real noise in a better manner.
Head speed can be changed in any situation with no performance influance.
Realtime Tuning feature:
Brand new feature that will allow you to set 20 parameters and 4 functions from any transmitter!
Possibility to assign 3 different realtime parameters and functions at the same time.
Support for Channel data pass-through to the CH0 servo output.
Support for Vibration Analysis during flight (In-Flight).
Parallel usage along with the Bank Switching or Jeti Integration with no problems.
Please check the Online Manual for more details.
Adaptive Rudder stopping algorithm:
Stopping behavior is automatically enhanced during flight to gain the best performance.
Stopping is automatically updated for both sides separately.
If overshooting is detected, it will be eliminated as possible.
Channel layout:
Support for 10 channels (Spektrum DSM2/DSMX, Futaba S-BUS, SRXL/SUMD, Jeti EX Bus).
Support for 8 channels (PPM).
Futaba S-BUS protocol:
Possibility to set Failsafe directly in the unit (Channels window).
Jeti EX Bus protocol:
Order of telemetry data was changed to make it compatible with DeviceViewer software (Please refresh telemetry variables in your transmitter).
Spektrum DSM2/DSMX protocol:
Fixed compatibility with Wifi-Link module - unwanted Binding problem.
Setup Wizard:
Helicopter profiles were updated (Oxy 3, Goblin 380).
Connection reliability was improved for the USB interface and Wifi-Link.
Rescue safety protection:
When initialized with engaged Rescue mode, the swashplate will signalize the event (Warning by Pitch-Pumps in the loop).
Software improvements:
Tooltips with more details.
Connection was improved when transmittion is unstable.
Minor useability tweaks.
You do not have to change any settings after the update from previous version.
Only minor tuning of the Governor Response and Holding performance parameters might be needed.
Futaba S-BUS users should set Failsafe in the General/Channels.
Update for the Spirit unit, Wifi-Link and Jeti Integration is available in our Download section.
Bu güncelleme ile piyasadaki bütün ünitelerin önüne geçmiş, çok sevindim,
Harika olmuş :halay:
Şimdiiii, öncelikle hayırlı uğurlu olsun :)
En eski Spirit kullanıcılarından biri olarak her zaman çok takdir ettiğim bir ünite olmuştur. Basit bir arayüz ile başlamış, zamanla gelişmiş, çağı hep yakalama çabası içinde olmuştur. İlk zamanlar fazlaca kaynak ve tecrübe yokken de Tomas son derece yardımcı olmuştu takıldığım yerlerde...
Gelelim yeniliklere :)
Realtime logging ve realtime vibration analysis gibi özellikler Brain2 de mevcut. Aynı şekilde Jeti integration da brain2 için duyuruldu, ne aşamada bilmiyorum. Zaten aramızda Jeti kumanda alan yok ve bilmiyorum olur mu...
Kuyruk stop behaviouru havada değiştirme, ideali kendi kendine bulma olayı... Eşittir vbar neo daki optimizer... Tamamen aynı olay, iki yöndeki stop gainleri ayarlıyor açık olduğu sürece...
Kanal olayı vbar neoda makroceller ile cesitlendirilebiliyor. Sayıları da 40... Bunların her biri klasik kumandalardaki kanallar gibi fonksiyon blokları oluyor ve kimi fiziksel çıktı verirken, kimileri iç fonksiyonları yerine getiriyor. Birbirine eklenip akış diyagramı vb de oluşturmak mümkün.
Farklılık olarak dikkatimi çeken sadece rpm sensör olayı. Çıktığında da governor çalışmaya devam ediyor düşük performansta denilmiş. Yani çıktığını pek görmesem de özellik olarak sunulmuş, sağolsunlar.
Özetle, güzel gelişmeler var. Yenilikleri yakalaması takdir edilesi... Ama hepsinin önüne geçmek için ortaya ciddi bir yenilik koymak gerek. Şu anda daha çok takip eden rolünde, çünkü arkasında dev bir firma yok. Daha kısıtlı imkanlarla hareket ediyorlar. İlerde neler olur bilinmez.
Spirit'e çalışmalarından dolayı tebrikler :bravo:
Genc, yeni fakat iyi gelişme kaydeden Spirit seviyoruz ve takdir ediyoruz :bravo:
Paylaşım ve bilgilendirme ıcın eline saglık Erhan. Yeni güncelleme tum Spirit ailesine hayırlı olsun :bravo:
Ben artık güncelleme yapmaya korkuyorum :)
Ama Goblin üzerindekini güncelleyebilirim.
Rasim detaylı cevap için çok sağol, ancak bildiğim kadarıyla ekstra kanal atayarak seçebildiğimiz özellikleri farklı kanallara atama daha önce duymadım, tabi ki vbar-vcontrol, spirit -jeti comboları haricinde bakarsak. Bunlarda tam kontrol var zaten.
Ancak özellikle fiyat performans açısından ele alırsak rescue fonksiyonu çok iyi çalışan, ekstra kanallara özellik atayabildiğimiz bir ünitenin bu fiyatıyla rekabette önemli bir avantaj elde ettiğini düşünüyorum. Mesela en son brain de autolevel çok başarılı olmasına rağmen rescue yi deneyip pek beğenmemiştim, spiritte rescue çektiğimde sapıttığını hiç görmedim.
Yeni güncellemeyi denedin mi Erhan'ım ?
Güzel gelişmeler var biraz araştırmam lazım :saygilar:
Rescue çekince sapıttı da mı sevmedin yoksa başka bi sıkıntı mı oldu bilmiyorum Kağan, orasını biraz açmak lazım da... Mesela şiddeti tatmin etmedi, daha hızlı çevirip yükseltsin gibi bir durum varsa, sanırım bu ayarlanabiliyor brain2 de. Ben kullanmadım, net yorum yapamam.
Fiyat olarak öncelikle Spirit Pro yu baz almalıyız sanırım, gerek servo giriş sayısı, gerek doğrudan satellite giriş sayısı, gerekse içindeki mikroişlemci olarak onu kıyaslamalıyız. Fiyatı 185 dolar. Sadece çekten alabiliyoruz, kampanya falan da olmuyor. Brain2 fastladde 155 dolar, kampanya zamanı daha uygun ( yerine göre %12 veya %15 olarak yansıyor bize vat durumundan dolayı)...
Kanal olaylarını bilmiyorum net, dediğim gibi brain2 kullanmak daha nasip olmadı. Emre abi zamanla daha net bilgi verir. Brain1 update ile rescue kazanıyor ama realtime logging vs yok, 2 almak lazım.
Ayar konusunda haklısın, vcontrol biraz farklı bir durum. Ekstra üç değil, ünitenin tüm fonksiyonları havada değiştirilebiliyor, knoblara atayarak kolay yoldan veya menüsüne giderek... Tabi uçakçı olsak güzel olurdu da, heli için havada ayar çok mümkün değil, model kıymetli :D
Gerçi uçakta da çok ayarlık bir durum yok ;D
İbrahim DEMİRBİLEK' Alıntı:
YOK DAHA DENEMEDİM. DAHA DOĞRUSU BENDE BU AKŞAM GÖRDÜM YENİ GÜNCELLEMEYİ. :eek:f: :eek:f: :eek:f:
Erhan paylaşım için teşekkürler.Spirit gerçekten çok güzel ünite.:thumbup:
Hayırlı olsun kullanan tüm arkadaşlara. :thumbup:
3 haftalik Brain2 kullanici olarak Kaganin yorumlarini Ozellikle merak ettigim icin BRAIN2 ile ilgili mesajlar ilgili konuya tasinmistir. Oradan devam edebiliriz :RCKolik:
olmaz .... :lollol: :lollol: :lollol: :lollol: Spirit konusundan alıntılara izin vermiyoruz.. :lol: :lol: :lol:
:RCKolik: :RCKolik:
Evet arkadaşlar, spirit 2.1 bugün test ettik, Izmir'den Tufan abiyle beraber hem onun 450L spirit konfigürasyon ve maidenı yaptık, hem de benim gob500 ile spirit 2.1 test ettim. Öncelikle şunu söyleyebilirim, kuyruk performansı harika. Kuyrukta optimizasyon olayı harika. Rescue her zamanki gibi süper kararlı. Özellikle kanala özellik atayıp realtime değiştirme işi anlatılmaz yaşanır diyorum :halay:
Kağan Kazancı' Alıntı:
Anlasilan yeni surum seni epey bir mutlu etmis Kagan %p Spirit kullanicilarin yeniden gozu aydin diyorum :hoppa:
Su ana kadar kullandigim unitelerden:
-- VBAR Neo da kuyruk optimizasyon ayari mevcuttu. Su ana kadar cok ucus yapmasamda GAUI X3 ve Logo 800'de VBAR Neo kisa surede olsa kullanma imkanim oldu. Fakat kuyruk optimizasyon yapma ihtiyaci hissetmeden default degerleri girdim. Belki pilotaj seviyemden olabilir ama isin acikcasi bunu ayarlama ihtiyaci hic hissetmedim.
Bunu ayarlayan ve memnun kalan birisi olarak, ucus sirasinda ne gibi olumlu bir tepki aldin biraz aciklayabilir misin rica etsek :RCKolik:
--"Kanal ve parametre atama" ozelligi ise uzun suredir kullandigim HC-3sx olan bir ozellik. Anladigim kadari ile bu ozellik yeni surum ile Spirit gelmis :thumbup: Bu ozelligin olmasi gercekten guzel bir ozellik ama ben yine hic kullanmadim ya da ihtiyac hissetmedim. Yine ornek olmasi ve anlasilmasi acisindan sen bugunku ucusunda mesela hangi parametreleri bu sekilde kullandin ya da ileride kullamabilirim diyorsun.
Tum bu sorularim biraz merak biraz da ozellile Spirit kullanicilarina yeni gelen bu guzel ozellikleri biraz daha iyi anlayabilmeleri adina, aman yanlis bir anlasilma olmasin ;) Yoksa her ne kadar hic Spirit olmasa da sevdigimiz bir Unite :halay:
benim anlamadığım mesela yeni eklenen bölümde pich-up compensation özelliği var ama bu ayar diğer setup bölümünde yok..
