Spirit Rescue Ters Çalıştı
Kağan Kazancı' Alıntı:
Abi versiyon kaç senin spiritte? Bilgisayara bağladığında ilk ekranda çıkıyor
Yanılmıyorsam 1.2.1 di Kağan
GT-I9300 cihazımdan Tapatalk kullanılarak gönderildi
Mustafa Çoban.' Alıntı:
İbrahim hocam bende bir spirit kullanıcı olarak takip ediyorum trim felan diyince kumanda aklıma geliyor bir sıfır model açarak onuda kontrol edebilirsin veya dongle varsa heli nin ayarları seciliyken dongle tak bakalım nasıl olacak.
Dongle takıp kumandadaki spirit ayarlarıyla simülasyonda mı deneyeyim mustafa?
İbrahim DEMİRBİLEK' Alıntı:
1.3.1 de denemen mümkün mü? iyileştirmeler aşağıdaki gibi:
Version 1.3.0 was released!
It brings many new features and improvements:
Spirit Pro support!
New sensor data processing.
Improved flight behavior and precision.
Improved Governor:
Max. parameter range was extended (has to be reconfigured).
New feed forward algorithm for immediate response and superior performance.
Support for more sensors.
Spoolup rate can be configured with higher precision.
Governor is activated at 40%+ TC.
Governor can be enabled/disabled between banks (check settings between banks!).
Improved bailout feature.
Throttle settings are available for disabled governor too:
Frequency can be configured to obtain much better performance.
Throttle Range - Max. value can be configured to 150 for disabled governor.
Channel Mapping was improved to display current channel values.
Improved Wizard:
Saving of the settings is available anytime with CTRL+S.
Unit can be disconnected anytime during the process of setup.
BEC tester was improved to determine if the power supply is sufficient.
New bank comparison feature.
New bootloader.
New secure format for the firmware.
New firmware flash procedure:
Much more secure (encryption, data integrity verification).
Firmware can be flashed easily even when any kind of failure occured previously (with the new recovery mode).
Improved Rescue and Stabilisation mode:
Stabilisation hovering level can be manipulated to a higher extent.
Rescue (Normal) has 1.5s climb out as with Acro mode.
Improved precision with more level corrections.
Improved UDI protocol compatibility.
Support for next channel in PWM connection with Spirit Pro.
New Rudder end-points setup.
Additional features with Spirit Pro..
Spirit Pro support!
Improved Governor:
Improved Wizard:
New bootloader.
Denerim kardeşim sürüm yükseldiğini bilmiyordum :rolleyes:
güncellemeden sonra ayarları sil baştan yapmak gerekiyor mu?
Gerçi mecburen yeniden yapıcam ama yine de bilgilenmek iyidir
Aynen birde spirit in ayar bölümünde kumandanin entpoint ayarlarının yapıldığı yer de de görünür kumanda da sıkıntı var ise
Abi bildiğim kadarıyla ayar gerektirmiyor, ancak benim tavsiyem bi fabrika ayarlarına geri dönüş yapıp, sonra yeni firmware yüklemek.
Sonrasında baştan ayar yapmak.
Çünkü senin problem de çok ağır kırımla sonuçlanabilecek birşey, bu nedenle üşenmeden ayarı baştan yapmak lazım :)
Bir de ayarlar bittikten sonra yerde holddayken rescue çekip denemekte fayda var, swash ne yapıyor diye bakılabilir.
Benim ünitem böyle bir sıkıntı yapsa mutlaka firma ile iletişime geçip kontrol edilmesi için gönderirdim. Yarın öbür gün tekrardan aynı şeyi yapar mı diye korku içinde uçulmaz.
İlker Sönmez' Alıntı:
Ki benzer durum zamanında benim de başıma HC-3SX gelmişti.
Özetle ünitenin ana kartı arızalandığı için Kurtarma özelliği arada bir ters çalışıyordu. Bunun ayar ve montajdan kaynaklanmadığını ispatlayınca kontrol için üniteyi Almanya'ya göndermemi istediler. Sonra da ücretsiz olarak ünitenin ana kartını değiştirdiler.
Dün Tomas'a yazdım sorunu izah ettim ayarsal sıkıntılardan bahsetmiş, bende özellikle aynı ayarlarla aylardır sorunsuz uçtuğumu olayın bir anda gerçekleştiğini ve ünitenin güven vermeyip tehlike yarattığını arz ettim kendilerine.
üniteyi gönderebileceğimi incelenmesini sistemsel bir sıkıntıdan kaynaklandığını ve ayarların fotolarını yolladım.
bakalım cevap ne gelecek.
bende bu arada bir sürüm güncelleyip yeniden ayarlarını yapıp bi deneyeyim diyorum. :saygilar:
Sonucu ve Tomas'in cevabını hepimiz merakla bekliyoruz Ibrahim.
Cevap geldi abi.
Kesinlikle ayarsal bir sıkıntı olduğunu iddia ediyo.
Subtrimlerle ilgili bilgilendirme yapmış.
Ben de son sürüme güncelleme yapıp en baştan ayar yapacağımı ve bunu kendisine ileteceğimi belirttim.
Sonucu bekleyeceğini söyledi.
İnşallah yarın Adana'da olursam hep birlikte yaparız abi :)
İnşallah sorunu çözersin. Ama durup dururken ayarlar neden bozulsun
Cevap geldi abi.
Umarım çözülür ve için rahat uçmaya devam edersin. Firmware güncellemeleri genelde bu tip şeyleri çözer,
trimleri ben kumandada deaktif yaptım spirit manual'de yazdığı gibi, subtrimler de 0 , sadece pitch kanalında subtrim'e kullanılabilir diyor ( gaz stiği ortadayken bilgisayardaki programda diagnostik ekranında 0 olabilmesi için )
İbrahim abi ,
Yorumların tamamını okuyamadım kusura bakmayın , yazıldımı bilmiyorum ama ..
Üniteyi model üzerine düz konumlandırdığını düşünüyorum , ancak program arayüzüne üniteyi ne şekilde monte ettiğini doğru yaptığına emin misin ?
Sprit'i düz monte ettin ancak programa ters monte ettiğini girdin.
Belki üniteyi ters görüyor gyro yu o yüzden aşağı doğru gidiyor ?
Biraz mantık yürütmeye çalıştım belki yararı olur :)
Cahit Kaş' Alıntı:
İnşallah çözeriz abi.
Bende aynı şeyleri defalarca söyledim ama ille de yeniden yap diyor ???
Umarım çözülür yarın adana da deneyimli arkadaşlarla daha detaylı bakarız inşallah.
Ama kafama takılan bir şey var.
Benim rudder servosu hariç tüm servolarda subtrim var kumandada :rolleyes:
Bu sıkıntı ise bu zamana kadar nasıl uçtu bu ünite anlamış değilim
