selamlar ,
nitro motorlardaki 15lik,40lık veya 52lik diye belirtilen ,görüşümce tamamen yanlış çünkü eğitimimizi metrik hesaplarla yapıyoruz,
bir açıklık getirmek istedim, bana 40lık motor birşey ifade etmiyor fakat 6,5cc . ekdeki tablo umarım bilgilendirici olur
Engine A B C C2 D E F G H J S Weight (g)
12(1,95cc) 33 11 57.5 40 60 40 25 35 49 M5 136
15(2,5cc) 33 11 57.5 40 60 40 25 35 49 M5 165
21(3,34cc) 37 14.5 69 44 68 52 29 45 55 M6 225
25(4,04cc) 38 15 70 45 78 55 30 47 62 1/4UNF 256
28(4,57cc) 38 15 70 45 78 55 30 47 62 1/4UNF 246
32(5,22cc) 37 15 75 44 72 52 31 45 56 1/4UNF 330
36(5,90cc) 37 15 75 44 72 52 31 45 56 1/4UNF 332
40(6,5cc) 44 17.5 85 52 87 60 35 52 69 1/4UNF 412
46(7,5cc) 44 17.5 85 52 87 60 35 52 69 1/4UNF 412
53(8,5cc) 44 17.5 85 52 87 60 35 52 69 1/4UNF 420
61(10cc) 52 25 97 60 100 66 42 54 80 5/16UNF 609
75 (12cc) 52 25 97 60 100 66 42 54 80 5/16UNF 614
91's' (15cc) 52 25 97 60 100 66 42 54 80 5/16UNF 720*
1.08 (17,2)1 57 25 105 70 114 73 47 60 90 3/8UNF 720
1.20(20cc) 57 25 105 70 116 73 47 60 92 3/8UNF 760
1.80(29,9cc) 67 37 135 80 135 95 58 78 115 3/8UNF 1528
* includes weight of 'quiet' silencer
1) and older .91 series3
Fourstrokes;
C2 (on fourstrokes) is distance from prop. driver to end of carb inc. choke (if fitted)
Weight is including carb. and standard silencer (inc. manifold)
.30 36 14 64 84 44 87 49 29 40 71 1/4 UNF 275
.52 44 17.5 80.5 115 51 101 58 34 50 84 1/4 UNF 455
.61 44 17.5 80.5 115 51 101 58 34 50 84 1/4 UNF 445
.65 50 21 89 119 57 117 66 42 55.5 96 5/16 UNF 630
.70 50 21 89 119 57 117 66 42 55.5 100 5/16 UNF 630
.80 50 21 89 119 57 117 66 42 55.5 96 5/16 UNF 630
.91 52 25 91.5 114 60 121 66.5 43 54 99 5/16 UNF 640
1.20 58 25 104 134 67 139 77 47 64.5 115 5/16 UNF 890
1.80 58 25 112 137 68 144 80 47 68 121 3/8 UNF 1040
1.60 1265
64cc 2800
Specifications;
Type Displacement
(cc) Bore
(mm) Stroke
(mm) Output (kw/rpm) Practical
rpm Weight
(g) Notes
12A 1.94 13.80 13.00 0.45/16.500 3,000-17,000 136
15A 2.45 15.50 13.00 0.50/19.500 3,000-17,000 165
21A 3.34 16.30 16.00 0.55/19.500 3,000-20,000 165
25A 4.04 17.40 17.00 0.65/18.500 2,000-18,000 256
28A 4.57 18.50 17.00 0.74/18.500 2,000-18,500 246
32A 5.22 19.00 18.40 0.86/17.500 2,000-18,000 330
36A 5.90 20.20 18.40 0.94/17.500 2,000-18,000 332
40A 6.46 20.66 19.28 1.14/16.500 2,000-17,500 412
46A 7.49 22.25 19.28 1.30/17.000 2,000-17,500 412
53A 8.49 23.68 19.28 1.46/17.500 2,000-18,000 420
61A 9.95 24.00 22.00 1.68/17.500 2,000-18,000 609
75A 12.40 26.30 22.00 1.80/17.000 2,000-17,500 614
91A 14.93 27.30 25.500 2.20/17.000 2,000-17,500 728
108A 17.22 28.50 27.00 2.40/17.000 2,000-17,500 733
120AR 19.96 30.68 27.00 2.70/9.500 2,000-9,600 940 Ringed
180AR 29.82 35.00 31.00 4.50/7.600 1,800-7,800 1528 Ringed
FS30AR 5.00 19.70 16.40 0.40/9,500 2,500-10,000 275 Ringed
FS52AR 8.56 23.00 20.60 0.71/9,500 2,300-9,500 455 Ringed
FS61AR 9.95 24.80 20.60 0.83/10,500 2,100-10,400 444 Ringed
FS65AR 10.63 24.80 22.00 0.85/10,500 2,000-11,000 630 Ringed
FS70AR 11.50 25.80 22.00 1.1/11,000 2,000-11,000 630 Ringed
FS80AR 12.80 26.50 23.20 1.2/11,000 2,000-11,500 630 Ringed
FS91AR 14.95 27.70 24.80 1.3/10,500 2,000-11,000 640 Ringed
FS120AR 19.96 30.40 27.50 1.6/10,500 2,000-11,000 888 Ringed
FS180AR 30.00 2.2/10,500 2000-10,500 1040 Ringed
Fourstrokes;
1.60 1265
64cc 2800
Specifications;
Type Displacement
(cc) Bore
(mm) Stroke
rpm Weight
(g) Notes
